Block huggers with an oil cooler
I remotely mounted the filter up front to keep the filter away from the exhaust. I ran the lines directly sideways from the engine to the frame rail down a heat reflective sheathing. If you wanted to add a cooler it would be easy enough to do in series with the filter up front.
The generic sbc summit brand worked fine for me, but I also used 90 elbows right out of the oil filter adapter to send the line straight out to the frame rails.
I used aeroquip lines, but you can plumb part of it with hard line. Just make sure you use at least some soft line to allow for engine shake.
