JCI Passenger mount........
Worked on the JCI mount kit tonight for my LS1. The driver's side went in fairly smoothly, but the passenger side mount seems to not be bent right...
Anyone else have this problem? Should I try and bend it to match the stock mount tower???
Thanks,
Tim
I am definately calling him on Monday. It will slow the chassis prep down but I still have a ton of other stuff to do in the meantime, hehe. I did some preparing on the engine itself tonight. I got the AC pulled, along with the PS pump, which was a PITA !!!
Got the "new" JCI mount installed. Fitment was flawless as it should be. I also split the trans open and removed the clutch and flywheel. Flywheel will be resurfaced on Tuesday. Replacing the clutch and having flywheel resurfaced was the last thing I needed to do to "prep" the engine itself before I dropped it in. I might be able to get the engine dropped in on Wed-Thurs !!!
My new toy
