May have found the problem, does this sound right?
Mauisnow13
I finally found my manual for the Z line (and a check for 25 bucks in it! haha). I read through the whole starting sequence section. great book, it lists everything, how it works, pretty much the whole start up.
Anyways, i figured out that i think i need a new ignition switch but I really have no idea. This just showed more of my symptoms on the list of problems for a bad ignition switch than anything else. My symptoms:
*Key won't start the car, but I can jump the car with a screwdriver by crossing it over the bolts on the starter/solenoid. This just takes a little while.
*When the problem first started, I could hear the accesory relay (at least i think) under the passengers dash clicking. Now the clicking has stopped too.
*The headlights turned on but dimmed out one night. Now won't work at all.
*Now, the blinkers stopped working, except for the hazards. When I push the brake though, they blinkers turn on.
I am not sure if the brake lights are still working, but they were. May have stopped. I'm still checking grounds, cause this may be the problem, but I am not sure. Also trying to check fusible links and such. I'm new to wiring so all of this takes a while. New battery cables and battery so I don't think it's that.
ANY ideas, the problem started out small, but is growing quickly. Starting to think it may be easier to just buy a new harness and replace it all. haha. getting frustrated. grrrrr.
