Guest jon-fernbrook@ll.net Posted February 13, 2008 Share Posted February 13, 2008 I'm stumped, along with my mechanic. My 78' 280Z starts and runs fine except after its been warmed up and allowed to sit between 3 - 30 minutes. If started between these times, the engine starts hard and runs rough for approximately 1 minute. Suspect it's running rich. To date, these items have been fixed/replaced: Iginition wire set Spark plugs Rotor Dist. Cap Ignition Rotor Fuel Regulator Temp Sensor Air Flow Meter Valve Thermo Time Switch Fuel Injector 'Computer' Any suggestions would be greatly appreciated. Absoluterly guessing at this point. Thanks all! Quote Link to comment Share on other sites More sharing options...
COZY Z COLE Posted February 13, 2008 Share Posted February 13, 2008 Use this link...http://www.atlanticz.ca/zclub/techtips/efisystem/280zfuelinjectionbook.pdf Go to the troubleshooting section...Hard to start only when hot. LARRY Quote Link to comment Share on other sites More sharing options...
Guest jon-fernbrook@ll.net Posted February 13, 2008 Share Posted February 13, 2008 Cheers! Appreciate the info. Quote Link to comment Share on other sites More sharing options...
Guest jon-fernbrook@ll.net Posted February 13, 2008 Share Posted February 13, 2008 Thanks for the response regarding my Z not starting when hot. I just chatted with the mechanic who has been working on it, and he indicated he tried everything listed on page 32 of the trouble shooting manual offered earlier by Cozy. Does anyone have any other possible suggestions (no matter how off-the-wall at this point I'm willing to listen) or contact names of people who might. I really appreciate the help. Thanks Quote Link to comment Share on other sites More sharing options...
JSM Posted February 13, 2008 Share Posted February 13, 2008 I didn't read the trouble shooting guide but were vacuum leaks included? What about electrical connection to the thermostat? I've heard that can cause problems as well. Quote Link to comment Share on other sites More sharing options...
Austin240Z Posted February 18, 2008 Share Posted February 18, 2008 To date, these items have been fixed/replaced:Iginition wire set Spark plugs Rotor Dist. Cap Ignition Rotor Fuel Regulator Temp Sensor Air Flow Meter Valve Thermo Time Switch Fuel Injector 'Computer' The only thing I can think of that isnt on your list of replaced parts is the O2 Sensor. There is a possibility that it could be your problem. I've seen O2 sensors do a lot of really strange things to cars when they go bad, and I've seen a bad O2 keep a car from starting. I've only seen that happen once, so it's kind of a long shot, but it's the only thing I can think of that based on your list you may not have checked. I hope that helps, Good Luck. Quote Link to comment Share on other sites More sharing options...
Thumper Posted February 18, 2008 Share Posted February 18, 2008 Leakdown test on the injectors Quote Link to comment Share on other sites More sharing options...
warrenHLS3083301 Posted February 18, 2008 Share Posted February 18, 2008 this is (Off the wall) Open up the distributor and chek the magnet that rotates inside, my mom's S10 had the same prob, after replacing the cold start valve, the alternator, and countless other things, the mechanic opened up the distributor and found that two of the six points on the rotating magnet had busted off. Why they busted off is another question. Quote Link to comment Share on other sites More sharing options...
