finishing disks-smooth to the touch
Ferd/289
If It's a 3000 grit disc like mentioned above, then heres how you use it. If you have a hood that needs polished, you can hit it first with 1500 dry on a DA Sander with an interface pad (its a foam pad that will make it easier not to dig into the nice flat surface you just painted.) Then after you get the orange peel or dirt out of the finish, you'll go back with this 3000 grit disc and use just a little bit of water and run this over your hood. This 3000 grit disc will take out the 1500 frit scratches and actually start to bring some gloss back to the panel. Then you hit it with a buffer and you're done. It'll cut down buffing time and woks pretty good. They're kind of expensive for the do it at home guy though.
