Newb question.. Starter motor wiring
rich280zxt
Alright, the wires connecting my starter motor are extremely fragile, and I accidentally broke one of the prongs off. Question is i can't remember where the wire hooks up.
A. There is a wire connected here.
B. There is a wire connected to this prong.
Somewhere there was another prong that a wire connects to? Anyone have any idea. I realize this is all very broad =[
well there aint much going there. You got the yellow wire with a spade connector to the solenoid and the main wire from the battery positive and a main wire from the battery negative. (actually that should go first to a bolt in the frame below the battery box and then to the starter) Keep the ground on the bolt don't run the cable direct to the starter. why not run some new wire. follow it back til you get to something good. It can't all be fried unless you had an engine compartment fire.
