HeadLight Housing Bolt repair
Guest DB240z
I was wondering if there was a way to get the hold 8mm screw that hold the headlight housing to the frame since i snapped a couple of them. On one of the pictures i tried drilling it out but that didn`t seem to work to well. Im open for any suggestions thnx for all your help fellas.
Driver Side Headlight Housing
Normal Bolt
Broken Bolt
The one i tried drilling out
thanks for the tip guys. i ended up grinding the bolt (threaded part) down even with the flange of the headlight housing and using a cut off wheel to take the head of the stud of then drilling the rest of the bolt that was left out of the flange. ill post pics tomorrow.
