Blown77Z Posted February 25, 2008 Share Posted February 25, 2008 Tonight I installed my new GM Hydraulic Cylinder. I'm wondering what's the best way to bleed it? Should I try and bleed it before I put the trans back together or wait until the trans is put back together? Also, the manual says to put a plastic/rubber line on the bleeder screw to bleed it, do I put the line INSIDE the small hole??? Picture is for reference. Quote Link to comment Share on other sites More sharing options...
Guest 72240Z Posted February 25, 2008 Share Posted February 25, 2008 It will have to be instaled in the car with the master cylinder and line hooked up to get all the air out of the system. Quote Link to comment Share on other sites More sharing options...
Blown77Z Posted February 25, 2008 Author Share Posted February 25, 2008 Ok, thanks for clarifying that for me As for the bleed tube, do you place it INSIDE the screw??? Quote Link to comment Share on other sites More sharing options...
Guest 72240Z Posted February 25, 2008 Share Posted February 25, 2008 I'm not sure. My LT1 has an external slave.Mabe some of the LS1 guys will chime in and help. Quote Link to comment Share on other sites More sharing options...
bschiltz Posted February 25, 2008 Share Posted February 25, 2008 No, you put the tube around the nipple or screw. It just keeps the fluid from spraying everywhere (like on your clutch) and makes it easier to clean up. Quote Link to comment Share on other sites More sharing options...
rwwisnesky Posted February 29, 2008 Share Posted February 29, 2008 Bleeding is a real challenge. Once it was in the car (1978 280Z), I had to lay on my back and approach the bleeder from the front. Manuever a deep socket into the hole and on to the fitting. Then attach a small ratched (requires a double jointed wrist). Then you can open the bleeder. It will run thru the socket and down the outside of the bell housing. It was a real joy to do, good luck. Another way is to drill a 2" hole in the tunnel with a flat blade bit and approach it from inside the car. If I ever have to bleed it again, I will do the hole routine. Quote Link to comment Share on other sites More sharing options...
ColtGT4g63 Posted March 1, 2008 Share Posted March 1, 2008 I just went through this bleeding process tonight. I cracked open the bleeder with an 11mm socket and short handle ratchet from the top. Then I hooked up a vacuum bleeder nipple down in there and pressed it up against the top of the bleeder hole, Filled the resevoir as it went down. Easy as that. For some reason my clutch fluid got VERY dark, VERY fast. Quote Link to comment Share on other sites More sharing options...
