brake line bulkhead fitting?
heres a similar bulkhead fitting i used EAR-963303ERL, avialable at summit... of course you will still need the nut and washer, -AN nuts and ferrules, and if ur using factory equipment, you may need a 10mm X -3 AN adapter for the "T" in the back, above the differential, if ur plumbing back that far... anyways, good luck!
cheers
ryan~
