Clutch problems
Soundmasterg
Hello all,
I've got a '72 240Z that was sitting 20 years. I just got it running today and it runs moderately well, though some carb adjustment will be necessary. The main problem I'm having at this moment is that the clutch doesn't work, and the pedal goes to the floor with no resistance. There is fluid in the reservoir, and I briefly tried to bleed it with no luck in changing the situation. Some fluid did come out the bleed nipple on the slave cylinder but not much...just a dribble. I plan to change everything on the braking system so maybe I should do the clutch master too? Or could something on the pressure plate be stuck or something? I'm at a loss to figure out what the problem is here. Anyone have any suggestions?
Greg
