Spark table
HB280ZT
Hi All,
Well I have been working an issue with turbo surge, as mentioned in this thread: http://forums.hybridz.org/showthread.php?t=129000
Well I desided to try something and see what happened. I started playing with the spark angle and I have almost gotten rid of what I thought was turbo surge. Not really sure how I did this but it works so I will take it. So if one of the MS gurus can explain it to me go for it!
Here are my old and new tables.
Hope this helps someone out!
Thanks for the heads up Moby!
Well for some reason when I export my spark tables it gives me the VE table instead??
However, I managed to capture the screen and provided it in my first post.
I should know better then to post stuff without first looking at it!!
Matt,
It was just something that I thought that I would try and it worked, go figure.
Do you have another idea that I can try?
Also if anyone has a spark table that works with there turbo setup I would like to look at it?
Thanks
So is anyone willing to share there spark tables?
Just remember to put what your setup is when you do this so that people have a reference to start with.
Here is my setup for the above tables:
MS 1 V3 with 29v Extra code
82 ZX turbo motor with N42 head using turbo cam
T3/TO4 turbo
intercooler
Tial BOV
running 12 psi boost
manual DIY boost controller
60mm TB
Thanks
I wouldn't pull timing after 4500, it's not helping. I would drop timing around peak torque and add it in after up to redline. It looks like most of the timing you pulled was off boost too and after 3400, I would start adding it after 3900.
One way to rid it of surge would be to pull alot of timing at lower rpms were you are experiencing surge.
Clifton,
Thanks for the info. I was looking at adding timing in the upper rpm but below 100kpa.
Matter of fact I am only getting surge above 3500 rpms and it maybe because I am taking timing out up high, hum!!
Will have to update my spark table again and see what happens.
Thanks
If you only surge above 3500 but can make full boost below that, I don't know if it's surge. As the revs increase the airflow requirement does too and reduces the chance of surging. I would think it would be in the 2500-3000 rpms range with that turbo.
