Engine build-Compression? questions.
ottoauto
Ok. I have a stock 240z with a l24 engine and e88 heads. I just talked to a guy and im getting a solid running 280z engine and tranny. Im curious as to how i might be able to swap some of the engine parts to make a solid comfortably running engine that will really pull. Im planning on using the l28 block with a 4 barrel carb, msd ignition, msd electronic ignition, and a earlier head such as my e88. I''m wondering if the head would interfere with l28 flatop heads. I also know that i could use the l24 rods, but i think that is going to put my comrpession way too high for what my plans are. I'm just wondering if anyone has any insight or recommondations for me. tell me what direction to go and ill probably follow the advice.
