jDm-FaIrLaDy_Z Posted March 7, 2008 Share Posted March 7, 2008 well i just got another 1975 280z and ive done a lot of searching on popping out of the intake and ive tried everything and its still doing it! when i hit the gas it starts popping and then it just stops it only does it around 800-1400 rpm then it stops i dont kno what to do any help would be great Quote Link to comment Share on other sites More sharing options...
Austin240Z Posted March 7, 2008 Share Posted March 7, 2008 well i just got another 1975 280z and ive done a lot of searching on popping out of the intake and ive tried everything and its still doing it! when i hit the gas it starts popping and then it just stops it only does it around 800-1400 rpm then it stops i dont kno what to do any help would be great Sounds like you're talking about backfiring through the intake, that's probably gonna be a timing issue. If everything is set properly but it continues to backfire, try retarding the timing a few degrees and see if it goes away. Quote Link to comment Share on other sites More sharing options...
jDm-FaIrLaDy_Z Posted March 7, 2008 Author Share Posted March 7, 2008 ive done that and no luck! Quote Link to comment Share on other sites More sharing options...
jasper Posted March 7, 2008 Share Posted March 7, 2008 Popping back on accel is usaually caused by a lean condition. That's why most carbs have accelerator pumps. I'd look for vacuum leaks, bad boot between MAF and throttle body, possible TPS, low fuel pressure, bad FPR. Also don't ignore the possibility of crossfire between the ignition wires. Test with a water spray bottle....Tommy Quote Link to comment Share on other sites More sharing options...
jasper Posted March 7, 2008 Share Posted March 7, 2008 Maybe tight valve clearance also. Quote Link to comment Share on other sites More sharing options...
jasper Posted March 7, 2008 Share Posted March 7, 2008 Cam timing if it's been played with, or jumped. Bad distributor cap is another possibility. Quote Link to comment Share on other sites More sharing options...
jasper Posted March 7, 2008 Share Posted March 7, 2008 or burned valves Quote Link to comment Share on other sites More sharing options...
jasper Posted March 7, 2008 Share Posted March 7, 2008 carbs LEAN>?????????????? Quote Link to comment Share on other sites More sharing options...
