Nissian pathfinder does no roll!! or start!! after swap!
Guest benchek2000
Guest benchek2000
I have a nissian pathfinder 1991 and i cant start if after the engine swap i had! whats the problem ? it makes some noise like spining and almost geting there but it does not crank..... also i cant roll it anywere! i turn the hand brake off and everything put it into nutrual and even hold clutch and i does not roll anywhere!! please somone help me
If somthing is binding against the bell houseing or engine etc. Could also be that the engine is seized and the clutch will not disengage. Iam hopeing for the frist. In nuetral dose the engine start to turn when you push the car? Problay not unless it is still in gear. My guess is somthing is bound up in clutch area, or the tranny is trash. Try turning the engine with a breaker bar.
