R200 Gearsets...
Mikelly
Do any of you guys know who sells R200 Gear sets? I'm thinking it might be cheaper in the long run to get a nice set of gears for my current 88 R200 LSD. Does Nissan Comp still exist???
Mike
mjk
Nissan Motorsports does and is available at 310-538-2610/ fax 310-538-1462
or email at mc.race@nissan-usa.com
They don't have anything more really than what's available on the street though. Although if it's not locatable on the street obviously it's great to have them around. They have the standard ratios from 3.36->4.11. Only the 3.36 that I know of with no OEM 12mm bolt source, I'm still skeptical that 10mm vs 12mm is really a weakness?? (seems to me it hasn't shown up as one yet). If I wasn't in school I"d be having bushings made so's my 3.36's and 4.11's could go into LSD pumpkins.
I didn't follow what you meant by 'cheaper in the long run' Mike? New gears vs. used?? Or a gear swap vs. a blower;^)
Here's your PN for the 4.11 12mm R&P 38100-16S01 and it has a '*' beside it was available as an OEM part (maybe you can get it thru normal dealer/OEM discounts??, not NM?) let us know:-)
Of all the things I've lost, I miss my mind the most.
Not fully related but I'm sure some who could use this info will read this thread, came across this in my archives and I'm sure some wouldn't mind having these PN"s handy. (for a clutch posi R200 from NM as mentioned above)
Complete p/n's and pricing are as follows:
38432-N9000 Friction Plate (1.75mm) 32.37 ea
38432-N9001* Friction Plate (1.85mm) 32.37 ea
38433-N9000* Friction Disc 34.79 ea
38437-71S00* Side Spacer 15.60 ea
All item are available. P/N's with an asterisk (*) are OE and will take an
additional day or so to obtain. Your order will be processed upon receipt
of a VISA/MasterCard # and proper shipping address. Ring & pinion sets
weigh approximately ten (10) lbs.
