nbesheer Posted March 13, 2008 Share Posted March 13, 2008 I'm running the tockico lowering springs, not sure what spring rate those are, and I have a S130 but still, it's pretty comfortable. Quote Link to comment Share on other sites More sharing options...
Mauisnow13 Posted March 14, 2008 Author Share Posted March 14, 2008 The problem with the VG30dett swap is that it is not a bolt in. I'd like to stay away from engine mount modifications for now. Maybe later when I have more money and knowledge. The L28et swap is just so easy and cheap. It takes some time to find a good deal on a donor car, but once you do it's nice. Bolts in, strong engine, cheap. Plus I can use a 280zx wiring harness for the swap pretty easily. Which is good cause my car needs a new harness anyways. Quote Link to comment Share on other sites More sharing options...
Silver Mine Motors Posted March 14, 2008 Share Posted March 14, 2008 so does anyone have 200lb f and 225lb r springs on there car now. if so how does it feel? comfortable? i'm going to order new springs today if i can get a response. Quote Link to comment Share on other sites More sharing options...
wheelman Posted March 14, 2008 Share Posted March 14, 2008 Mauisnow13, I think you made the right choice to stick with the S30 and agree an L28ET is a more realistic swap than a VG30DETT. The VG motor not only needs custom motor mounts but also requires notching the frame rails to clear the turbos. It's a much more complicated swap for very little extra in return, an L28ET can be built into a very strong motor. ***** WARNING THREAD JACK ***** BajaRacer, I'm was running 225f/250r and it wasn't bad at all. I'm swapping the front to back and vice-versa to see if I can reduce the tail happy nature of the car. I agree with what was stated earlier, your spring rates are pretty stiff for street use. BTW: What brand and length are the springs you're currently running? What struts are you running and if adjustable on what setting(s)? Wheelman Quote Link to comment Share on other sites More sharing options...
Silver Mine Motors Posted March 14, 2008 Share Posted March 14, 2008 sorry for jacking your thread i hate making new onces since this topic is so opinionated. right now i have eibach 12 inch springs in front and back. i'm adujsted to 2 in the front and 1 in the back. wheelman do you think it would be to stiff if i put my 275 fronts in the back and put new 250 in the front. i live in l.a. and there are a lot of bumpy streets. Quote Link to comment Share on other sites More sharing options...
