Jared Posted April 17, 2009 Share Posted April 17, 2009 How did you mount the Griffin radiator? Did you weld on tabs or does it come with a mounting kit? 240Z_Master said: I want to say my radiator is this one "Griffin 1-28182-X" @ www.summitracing.com My inlet and outlet is on the same side so I don't have to worry about that crossover pipe. The other benefit to a radiator like this, is the fact that it is a cross flow radiator, meaning it cools the top, then goes down on one side end tank, then down to the outlet. Basically snakes through the radiator twice, so technically it should get a tad bit more cooling if the fan is effective? Can someone verify this fact with me? Specs should be 22" Wide x 19" Height x 3" Thick. You can search the website for radiator, and click through until you find the specs. The inlet hose and outlet hose should be passenger side. Click Here Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted April 17, 2009 Share Posted April 17, 2009 Jared said: How did you mount the Griffin radiator? Did you weld on tabs or does it come with a mounting kit? Tabs welded on. Quote Link to comment Share on other sites More sharing options...
