fl327 Posted December 13, 2000 Share Posted December 13, 2000 hey guys have a problem here sometimes when i want to go into reverse like in a parking space, ill go into the reverse gear and give it some gas, and the car feels like its going over a small hill or something like that, then its ok and it goes and drives ok. also say im driving along and come rolliing to a stop, i put it in neutral, and i hear a small clicking noise from my differential what does this mean, is my r200 out of comish ion or what? im going into the suspension and tranny for christmas break, and want to know if my differential would be ok once i put new bushings and a new mount up in there? or should i hit the boneyards now and grab me a new one, what should i do???? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 13, 2000 Share Posted December 13, 2000 Ummm, if your stopped, wouldn't the rear end be unable to make any noise? Nothings moving, driveshaft is stopped, so the click must be coming from somewhere else right? Or are you saying as you rolled to a stop and put it in neutral it was clicking? Lone [This message has been edited by lonehdrider (edited December 12, 2000).] Quote Link to comment Share on other sites More sharing options...
fl327 Posted December 13, 2000 Author Share Posted December 13, 2000 im not sure whats going on for certain ill be in reverse right, and when i give it gas, it will stall for a second, i hear and feel a loud ass clunk, then it goes and does its thing fine, moving in reverse just had abad experience on the freeway as well, at about 2500 in 4th doing about 75 (3.36gears and a four speed muncie) the rear end started vibrating so hard and loud i had to pull off and take thestreets to where i was going, what does it all mean, ?????? thanx guys [This message has been edited by lonehdrider (edited December 12, 2000).][/b] Quote Link to comment Share on other sites More sharing options...
Mike kZ Posted December 13, 2000 Share Posted December 13, 2000 It could be U-joints, did you check all of them? ------------------ http://members.tripod.com/~SnowSurfer/mikekz1.html Quote Link to comment Share on other sites More sharing options...
pparaska Posted December 13, 2000 Share Posted December 13, 2000 Have you checked: Half shaft u-joints, Driveshaft u-joints, Halfshaft to companion flange bolts, Driveshaft to pinion flange bolts, Front mount (is it torn) and mount bolts. Mustache bar nuts to studs from diff Mustache bar bushings? Nuts at bushings? ------------------ Pete Paraska - 73 540Z - Marathon Z Project pparaska@home.com Pete's V8 Datsun 240Z Pages Quote Link to comment Share on other sites More sharing options...
BLKMGK Posted December 14, 2000 Share Posted December 14, 2000 I'm betting front mount - shall we start a pool? I'll bet that the rear is rotating a few degrees at least when he puts it into reverse or forward from a stoplight. Saw this on a Mustang once except that with a live rear the whole axle was moving due to torn bushings - very scary! Of all the things Pete mentioned, and I'd check them all, I'm betting that the front mount is the only one of them that could allow for that much play... Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 14, 2000 Share Posted December 14, 2000 Ok, I'll take U-joint in the pool because of the clicking... Lone Quote Link to comment Share on other sites More sharing options...
