87 turbo cars diffs?
Guest scca
found a 87 all white turbo at the wrecker..
its 100% there and all original..
i thought they had LSD?? its a 5 speed car
i'm taking all the 5 lug stuff and if anyone needs anyparts i can get you a price..
red interior and ttops there still.
Mike
mike@fonebooth.com
http://www.fonebooth.com/brakes.html
raceparts and brake upgrades.
That's the all-white SE? White wheels too? Pretty rare these days I think. If so, that's a Viscous R200, like James Thagard has cobbled into an early Z and put different CV shaft parts (AMC?) together to work instead of the clutch R200 and 280ZXT CV shafts.
yep its all white - white mags totally original- motor tired, ..no crash damage..
but NO lsd... well if it is its totally worn out, i can turn the rside cv shaft and the left is on the ground still...
Mike
LSD after 4/87 only. Viscous lsd on the SS models(pearl white paint, white wheels, white door handles, recaro seats, black interior, non-adjustable shocks).
You can spin 1 wheel with the viscous by hand because it has no clutches - it'll just have resistance to spinning because you're moving the fan plates through the viscous fluid.
Check for the finned rear cover. If you can see through the 1/2 shaft holes of the diff, it's viscous. If you can't see through the diff then it's a clutch lsd. I'm not sure if you can see through open diffs or not.
Morgan
http://z31.com/~morgan/s30
http://carfiche.com
