SleeperZ31 Posted March 30, 2008 Share Posted March 30, 2008 Anyone know of a better direct-fit or otherwise compatable manual transmission for the vg30e or z31's? Anything that might have better gearing/stronger as im looking to improve 0-60 times and overall driveability by any means possible. Quote Link to comment Share on other sites More sharing options...
Racinjitter Posted March 30, 2008 Share Posted March 30, 2008 fs5r30a. That is the strongest bolt in tranny made for a vg30e/t Quote Link to comment Share on other sites More sharing options...
hoov100 Posted March 30, 2008 Share Posted March 30, 2008 i wonder if you could use a z32 TT gear set in a 30a housing. Quote Link to comment Share on other sites More sharing options...
Racinjitter Posted March 31, 2008 Share Posted March 31, 2008 hoov100 said: i wonder if you could use a z32 TT gear set in a 30a housing. http://www.z31performance.com/forum/viewtopic.php?f=3&t=2536 The info is in there, just scroll down to read kennedy's posts. Also rfs5r30a is the same exact internals as 87-89 z31t fs5r30a and rb25det rfs5r30a. Quote Link to comment Share on other sites More sharing options...
SleeperZ31 Posted April 1, 2008 Author Share Posted April 1, 2008 Thanks, i figured the Turbo z31's had a better tranny just didnt know for sure. Quote Link to comment Share on other sites More sharing options...
hoov100 Posted April 1, 2008 Share Posted April 1, 2008 just watch out for that 5'th gear its pretty big and acceleration is pretty slow until you get into boost.. Quote Link to comment Share on other sites More sharing options...
SATAN Posted April 14, 2008 Share Posted April 14, 2008 SleeperZ31 said: Thanks, i figured the Turbo z31's had a better tranny just didnt know for sure. Not all turbo z31's just 87-89 turbo z31's. Quote Link to comment Share on other sites More sharing options...
mtcookson Posted April 14, 2008 Share Posted April 14, 2008 My info is in the Z31 Performance post above but to use a Z32 5-speed on a VG30E(T) you just need an 89-91 Maxima flywheel (early 85-88 might work as well if any are made for them) along with either a Maxima clutch kit or an 84-86 300ZX clutch. Z32 throw out bearing and starter work perfectly with this setup. Quote Link to comment Share on other sites More sharing options...
zmech Posted May 30, 2008 Share Posted May 30, 2008 mtcookson said: My info is in the Z31 Performance post above but to use a Z32 5-speed on a VG30E(T) you just need an 89-91 Maxima flywheel (early 85-88 might work as well if any are made for them) along with either a Maxima clutch kit or an 84-86 300ZX clutch. Z32 throw out bearing and starter work perfectly with this setup. Do you know for sure if the internals of the Z32 transmission will fit the Z31 FS5R30A casings? If so I have a casing here that can be built up with the internals. Quote Link to comment Share on other sites More sharing options...
HowlerMonkey Posted June 19, 2008 Share Posted June 19, 2008 Since a very similar tranny came on the pathfinder 2wd models, I would assume the clutch application to work with that tranny as well. Quote Link to comment Share on other sites More sharing options...
