280z mass air conversion?
  • Administrators
hey i have a 78 280z and have been looking for an aftermarket mass air set up for my car. there use to be a guy in my town that did it but hes no longer here so, if someone knows where i can find one please let me know. thanks.
Where do I begin?
OK, lets start with your shift key.... please use it.
There may be some terminology conflicts in this thread. Those always add to the confusion, but in a nutshell, your engine is modified extensively enough that you really ought to be considering a complete stand alone EFI system. You do not need a MAF system per say. MAF is a load measuring device, much like an AFM, MAP sensor, or even TPS (if configured that way). They all go about it differently and they all have their advantages and disadvantages. But they can all serve the same principle function. Load.
There is a simplified description here... http://forums.hybridz.org/showpost.php?p=808851&postcount=1
the stock air flow meter was more of an on/off switch than an analog sensor.
Not remotely true.
  • Administrators
Fella’s Ron was being awfully nice.
To ALL of you guys with the lazy/broken pinkies, read this link!
http://forums.hybridz.org/showthread.php?t=131518
If you can’t type, DON’T! HybridZ is NOT the local mall and we are not IM texting each other!
MAS isn't gonna do you much good inless you have a aftermarket ems setup. the stock air flow meter was more of an on/off switch than an analog sensor.
Shift,
2 things.
1) Please do NOT guess when answering a tech question. Please read this link regarding guessing;
http://forums.hybridz.org/showthread.php?t=131790
2) The AFM is NOT an on–off device. This thread, in post #19 in a manner of speaking, describes how the AFM operates;
http://forums.hybridz.org/showthread.php?t=132075
If this keeps up will have to institute a nap time after our banana, apple sauce, and cool-aid lunch…
