clutch master cylinder rod
Guest RagedApe
Guest RagedApe
I did an auto-->manual swap and ran into problem. The master cylinder's rod from autozone is short. Is there a site that has the long
one or is there a way to make it work? I've tried other auto stores and it will take at least a week not to mention it might be a wrong length again. The car is a 78 280z with a 79 tranny
I had that problem with the rod for the Chev master cyl. I just cut the head off a bolt the right thread, welded it on to the short rod to extend it, and ground the weld down. Worked great until I changed masters and the tilton had a longer rod.
Mike
Guest RagedApe
that what i had in mind but I don't have a welder or any welding experience. Even so, I still don't know the correct length of the rod.
