Any sugesstions how to pressurize carb.?
Guest Michi2008
Guest Michi2008
I have a chevy Malibu 1978 twin turbo engine 327 ,with holley 750 doble pump mechanical secondary. but I'm having trouble when its running and when it receives boost it starts to have problems.I've tryed increasing and decreasing gas but no results.Is their a trick for the holley to get it running well:confused: .Please help Thanks
Pressurise the float bowl, and raise your fuel pressure on a 1:1 ratio to your boost.
At an idle fuel pressure of 4 psi, you will need 9 psi of fuel pressure to the carb at 5 psi of boost.
It's either that, or you suck through the 750, into each of the twin turbos---which isn't hard to replumb either.
V8 forum?
  • 3 weeks later...
Guest martell06
theturboforums.com has a section dedicated to blow thru setups and builds.
top notch website - all the info you'd ever want to know and more.
