jeffer949 Posted December 9, 2008 Share Posted December 9, 2008 I believe the Z31zxt cas uses the same size wheel as the L28et. I know you can make the cas from the z31 work inside the l28et dizzy. I know this cause im running it. I also believe that it has different sized low res slots. Maybe this would work for you. Quote Link to comment Share on other sites More sharing options...
SATAN Posted December 11, 2008 Share Posted December 11, 2008 I believe the Z31zxt cas uses the same size wheel as the L28et. I know you can make the cas from the z31 work inside the l28et dizzy. I know this cause im running it. I also believe that it has different sized low res slots. Maybe this would work for you. Well, thats not the problem. I already have the z31 dizzy, The problem I am running into is that I am trying to figure out how to put the smaller z32/RB disk into my z31 dizzy. The reason is that I have an AEM wheel that I am trying to use, but it is only made for the z32 and the RB. I may just have to buy a z32 CAS and hack my z31 dizzy to make it fit inside. After all this experimental thinking I have been doing though, I may just end up using the OEM CAS from the z31 from my project. People seem to have OK luck with those I guess. Quote Link to comment Share on other sites More sharing options...
