BSD Posted April 24, 2008 Share Posted April 24, 2008 This may be a repeat question.. but I've searched for awhile, and alas.. haven't found anything directly pertaining to my question, so here goes. I am running N/A right now.. l28 manual.. I should have my MSD coming within the next week and wanted to run MS, ( while the car is apart and unwired it would make my life ALOT easier to install a standalone system with the car apart )The problem is that I didn't know if I could run MS N/A and just switch its settings for turbo later on... I wanted to go with the MSnS.. would I just have to desolder and resolder the board when I switch and add wiring for new sensors? Would there be more to it besides that? Sorry. >.> Thanks. Quote Link to comment Share on other sites More sharing options...
dexter72 Posted April 24, 2008 Share Posted April 24, 2008 When searching sometimes you will be looking for hours. There is a lot of info on here. Search for fuel only posts or ms on n/a engine. If you haven't done so look through the useful posts sticky. A lot of good info in there too. So save the links that you need. Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted April 24, 2008 Share Posted April 24, 2008 I'd recommend swapping in the turbo distributor now, as this makes spark control a lot easier. Other than that, you can use the same sensors for both applications. Quote Link to comment Share on other sites More sharing options...
BSD Posted April 24, 2008 Author Share Posted April 24, 2008 I did look for quite awhile.. but like I said, I didn't find anything directly answering my question, i'm not trying to be lazy and not look for the answer myself, I just can't find it.. I appreciate the info, and thanks Matt, I will try to get ahold of a turbo dizzy. Quote Link to comment Share on other sites More sharing options...
mobythevan Posted April 24, 2008 Share Posted April 24, 2008 Once you switch to running a turbo re-tune your fuel table. You will reach new areas on the VE table that you didn't use before (on boost). Quote Link to comment Share on other sites More sharing options...
BSD Posted April 24, 2008 Author Share Posted April 24, 2008 Awesome, thanks guy, I guess the only issue i'll run into is re-tuning. Good deal, i'm going to read up some more on exactly what MS I want to purchase and go from there. *thumbs up* Quote Link to comment Share on other sites More sharing options...
Noddle Posted April 25, 2008 Share Posted April 25, 2008 Hi, not to hijack your thread, but I'm planing to buy a MS2 using a v3.0 board, I'm plaining to use the stock electronic distributor, which uses the E12-80 module, but later run EDIS, my question is, will I need to make hardware changes to the MS unit ?, also what version / software would be best to use ?, it's a bog standard L24e Nigel Quote Link to comment Share on other sites More sharing options...
