zmaster Posted April 24, 2008 Share Posted April 24, 2008 I started and let my 75 280z today and let it idle for a little while, and I noticed somethin....... My oil pressure was about a 1/4 inch from the 0 lineI was wondering if this is normal or not. If not than I think I have bigger problems that my fuel pump. Quote Link to comment Share on other sites More sharing options...
MatMan Posted April 28, 2008 Share Posted April 28, 2008 If it's the stock L6, yup. it's normal. Quote Link to comment Share on other sites More sharing options...
Brett6485 Posted April 28, 2008 Share Posted April 28, 2008 The sending unit caused the problem for me, swapped in a new one and all is well. Quote Link to comment Share on other sites More sharing options...
zmaster Posted April 28, 2008 Author Share Posted April 28, 2008 ok I was just wanting to make sure because i didn't want to seize up my motor and cost myself even more money. Quote Link to comment Share on other sites More sharing options...
mom'sZ Posted April 29, 2008 Share Posted April 29, 2008 The sending units for the stock Zcar oil pressure gauge are notorious for going bad. They are expensive to replace as well $40 - $60 buck if I recall depending on if you go OEM or aftermarket. I had one that leaked through the body of the sending unit as well and what a mess! An aftermarket gauge is a good alternative. These motors don't have a boatload of oil pressure when they are right and high milage examples seem to run fine with very little oil pressure. The oil pump has a high pressure relief vavle (I think) that limits the oil pressure to 60 psi. My brand new motor idles at 15-20 psi once warmed up and at mid range rpms is around 40-50 psi. Quote Link to comment Share on other sites More sharing options...
zmaster Posted April 29, 2008 Author Share Posted April 29, 2008 ok well it seems to run fine for now, I desperately need a oil change, and an oil filter. I am going to use Royal Purple Full Synthetic 10W or 5W 30 with K and N's oil filter. These are the oil products I use all of the time. I used to use Q full synthetic, but i switched. Quote Link to comment Share on other sites More sharing options...
woldson Posted April 30, 2008 Share Posted April 30, 2008 Just go with some castrol 10-30 and a fram oil filter untill you get the thing really running;). Save a few bucks. Btw congrats on how far you have made it in such a short time. Your bro still helping you? You should of added him in with your photo of yourself. As far as your paint job, it looks nice, in your photobuk you add a pic that finnally showed off the paiint job better. Quote Link to comment Share on other sites More sharing options...
zmaster Posted April 30, 2008 Author Share Posted April 30, 2008 well thank you for the comment on my paint job, I love it now< and my neighbors come over to admire my car in the mornings sometimes. And yes my brother is still helping me. Quote Link to comment Share on other sites More sharing options...
