JustinOlson Posted April 24, 2008 Share Posted April 24, 2008 Current Setup Planning: Car: 1977 Datsun 280z w/ factory unibody w/ cage Weight: 2750-2850lbs w/ driver Engine: Toyota 2JZ 185ci. 9500rpm redline Turbo: Borg Warner S480 T6 1.32 A/R. Supports 1150WHP. Nitrous: Used to flash the converter and spool turbo to 40psi. Tires: MT 275/60-15 Radials on 8†wheel Suspension: Independent Rear Differential: 3.69:1 R&P LSD w/ 9.05†ring gear. Wheel Base: 90.7†I’m trying to decide between the TH400 and Glide for this car. I will be driving this car on the street and on some short trips. I think the glide would be better for launching on the radials. What do you guys think I should do? Do you guys think I'll have trouble cruising around town with this small engine and the steep first gear? TH400 Ratios: 2.48:1 1st 1.48:1 2nd 1:1 3rd Glide Ratios: 1.76:1 1st 1:1 2nd Regards, Justin Olson Quote Link to comment Share on other sites More sharing options...
SLVRBLLT40 Posted April 25, 2008 Share Posted April 25, 2008 PowerSlide: Slow 60ft (depending on converter used) Good mid track One less shift the trans has to make If the tires spin off the line, you pretty much have to completely let out to control wheel spin Much lighter than the TH400 The preffered tranny for high HP cars TH400: Faster 60ft Can take more HP Easier to modulate wheel spin Weighs more Has that extra gear to shift Preferred trans for street driving and moderate HP Quote Link to comment Share on other sites More sharing options...
Pyro Posted April 25, 2008 Share Posted April 25, 2008 400's are huge. I have one in my truck and can't image putting that thing in a Z. I had it rebuilt last year and getting that mass of aluminum back onto the back of that 454 was tough. I would use a built th350 before using a th400. A th350 built for drag racing can handle lot of hp. install a trans brake and a manual valve body. A th350 can handle your engine easily if built right. Quote Link to comment Share on other sites More sharing options...
tkach Posted April 25, 2008 Share Posted April 25, 2008 I have a Turbo 400 in my 75 It fits snug and needs no mods to the trans tunnel to fit. However it does present a problem as far as exhaust routing is concerned. Quote Link to comment Share on other sites More sharing options...
Pyro Posted April 25, 2008 Share Posted April 25, 2008 Wow, you got that thing in there! is your engine in the set back position? exhaust routing is always a problem with automatics. that big oil pan is a problem. Quote Link to comment Share on other sites More sharing options...
tkach Posted April 25, 2008 Share Posted April 25, 2008 I have a sbc set back as far as I sent it back, It clears the tunnel completely! even allowing space to run trans cooler lines, and a dipstick! Its a tight fit but not as bad as you would think and its hides at least level if not a tad bit higher then stock frame rails. Quote Link to comment Share on other sites More sharing options...
dr_hunt Posted April 25, 2008 Share Posted April 25, 2008 IMO building a th350 to handle high hp is going to take some money. The th400 will handle alot of hp, high hp, like blown alky BBC's but properly built and some money as well. Glide's are relatively simple, cheaper to build and IMO a better route to go if cost vs. reliability are a concern. Kind of a preference thing. For a glide, things you'll need, 1.76 gearset or aftermarket gear set, th350/400 splined input shaft, steel hub for the high drum, machined pistons for more clutches in the reverse pack and high drum, quality clutches and kolene steels, master build kit, kevlar band, dual o-ring servo, t-brake, mod the oil line holes in the case to 1/4" and retap. I have both a bte pump and a stock pump, both work fine with a T-brake as long as the stator shaft is for the th350/400 input shaft, mod the case by drilling 2 holes for the t-brake. You can build a glide for about $800 less converter. They are simple and truly a DIY tranny if there ever was one. You can get crazy and spend alot more if you want but IMO it isn't necessary although the aftermarket cases look cooler when the trans is sitting in the floor of the shop. As for slower 60' times I don't think so, check the timeslip database or look at my sig. Quote Link to comment Share on other sites More sharing options...
SLVRBLLT40 Posted April 25, 2008 Share Posted April 25, 2008 Yeah, your are deffinately running a very quick 60', but by your 1/4 mile time, I'd say your car has some horsepower hehe. On a car that sees mostly street use, more times than not, your 60' will suffer, since the car will usually bog off the line or just totally annihilate the tires if it's got enough power to break them radials loose. Quote Link to comment Share on other sites More sharing options...
JustinOlson Posted April 25, 2008 Author Share Posted April 25, 2008 My thinking is the long 1st gear will be easier on the radials. It will also allow me to use the stock ring and pinion in the R230TT as well. Justin Quote Link to comment Share on other sites More sharing options...
dr_hunt Posted April 26, 2008 Share Posted April 26, 2008 Yeah, your are deffinately running a very quick 60', but by your 1/4 mile time, I'd say your car has some horsepower hehe. On a car that sees mostly street use, more times than not, your 60' will suffer, since the car will usually bog off the line or just totally annihilate the tires if it's got enough power to break them radials loose. IMO most V8 z's, v6's, and high hp l6's tend to anihilate the tires out of the hole from a dead stop. My thinking and experience comes from that fact. Any car hooking up rather than smoking the tires out of the hole, hp for hp, will be faster, hands down. It doesn't take all that much tq from a good motor to burn the hides off any z car. The glide makes alot of sense from that standpoint. Drawback is no overdrive commonly desired for street use. Quote Link to comment Share on other sites More sharing options...
Z-Gad Posted April 27, 2008 Share Posted April 27, 2008 No OD in my TH400 either, but with the forward shift pattern and vacuum connected, I can just put it in drive and putter around town like any other auto with the tranny shifting through the gears for me. I use a B&M ratchet shifter and it allows me to shift manually when I want to. I street drive mine a good bit, so that's one of the reasons I went with the TH400. I've managed a few high 1.3xx 60's, although it is on the footbrake. figured I'd throw in my .02 Mike Quote Link to comment Share on other sites More sharing options...
JustinOlson Posted April 28, 2008 Author Share Posted April 28, 2008 Yeah, The final drive is the same between the glide and the Th400. I think since I plan on using the R230TT w/ 3.69:1 R&P, the glide 1st would be helpful. If I used that rear gear on a TH400, I'd be shifting pretty fast out of 1st. Justin Quote Link to comment Share on other sites More sharing options...
