t56 weight?
Guest brad
how about the wct5?
reason I'm asking, I'm looking for a cheapo engine/tranny hoist and I'm wondering what's the worst in terms of capacity I would need.
one more - anybody got a cheap source for hoists?
how about the wct5?
120-125 lbs sounds about right from when I lifted my T56 out of my truck to the ground. Its nothing you want to schlep around very far thats for sure (if you do you'll make faces like this: icon_mad.gif ). Judging by the case and the fewer gears in the T5, I'd guestimate probably 85-90 lbs.
Regards,
Lone
Brad,
Not sure what you have in the way of commerce there in Ashevill; as far as engine hoist & stands go-look for a "Harbor Freight" a "Northern Hydraulic" or go to your nearest "Sams". Usually the Harbor Freight & Northern Hydraulics will have a "Lowest Price Gaurantees" & you can play each one against the other for a lowest price gaurantee!
Not sure but I think all Northern Hydraulic stores now go by "Northern".
Dont get to cheap of an engine stand-I'ver heard stories about the cheap one's colapsing under the weight...I'ld opt for the slightly more expensive engine stand/as for the hoist-they're usually pretty close in capacity unless you're pulling Cummins & Catapillar engines icon_eek.gif
One consideration on the hoist; make sure you get one w/adjustable length legs. Some times on my hoist when I have to extend picker part of the hoist-the rear wheels at the base will begin to lift....luckily my legs on my hoist extend & the balance is restored: just FYI.
Kevin,
Yea,Still an Inliner)
[ April 27, 2001: Message edited by: Kevin Shasteen ]
Guest Jason
Check the big online vehicle replacement parts dealers for engine hoists. I got mine for under $200 shipped UPS after using a 15% off coupon.
