Looking for a L28 NA Fuel only msq
Trys_Hard
The LeMons car used the 8X8 map from above.
Instead of using the MSQ, take a look at the maps, and simply enter the values into your Megasquirt. It may not be a downloadable 'plug and play' but you can populate the maps really quickly, and even if the engine is not the 'same' there is great lattitude in the tuning...it will run, you just may need to run some tuning runs to clean it up where the peak torque area changed. Above there and below there, there is WIDE lattitude in the tuning and what will run.
