madkaw Posted May 7, 2008 Share Posted May 7, 2008 Once again searching has left my little brain hurting more then anything.:ugg: I have a 2.4 that i am mating to a 82 turbo BWt-5. When I had the engine assemblies balanced I gave the machinist the 225mm flywheel instead of the 240mm flywheel. From what i read from the archives the 225mm will be fine for my hot street motor. I want to use the 225mm because it has been balanced but i want to make sure i put this together correctly. I have read that for my set-up, I can use the 225mm with the BWt-5 as long as I use the 225mm throw out collar along with the 225mm clutch kit. Do I also need to use a fork from a 225mm flywheel? I would be glad to hear any good deals anyone has gotten on a performance clutch for their car. Please correct me if i have this wrong so I can get this clutch ordered. Quote Link to comment Share on other sites More sharing options...
