LS1 is in...NOW?????
how does the stock chasis harness get wired to have POWER to chasis electrical ie.(ignition,lights,horns,air,fuel pump....ect.)75 280z
1. what stock fusible links do i use...pix please,if you could
2. which stock wires do i reuse, and not used....pix please
ecm is sent off to get redone
harness is cleaned up
For Mine, I ran a thicker power wire from the battery into the car. and off of that I had a junction point that fed relays. The relays would be tripped by the ignition turning to #2 position, the fuel pump signal from the PCM, and the Cooling fan signal. The other sides of the relays would go to whatever circuit they're feeding. For the Orange wire on the PCM, since it is a constant 12v hot wire, I just used an inline fuse straight from the batt. to feed it. Hope that helped.
