Madkatt44 Posted May 16, 2008 Share Posted May 16, 2008 I want to put a 30DETT into my hot rod, 1927 model T. I just want to make sure i am going to have all the parts i need. It is a full kustom car and I want to do something different. Please I don't want to hear it cannot be done or your better off with a SB. It will work perfectly for my application and i love the look/perfomance of this engine over the SB Required: Engine with turbos exhaust manifold Tranny transfer drive shaft Wiring harness IC ECU mounting brackets Is there anything else i will need or that would help. Also where is the best place to get a wiring harness and ECU? Does Mega squirt work for this engine? if not what other Stand alone system would you recommend? Thanks Quote Link to comment Share on other sites More sharing options...
Madkatt44 Posted May 16, 2008 Author Share Posted May 16, 2008 Also what is a good tranny for this engine if other then OEM Quote Link to comment Share on other sites More sharing options...
ShaggyZ Posted May 16, 2008 Share Posted May 16, 2008 Go MegaSquirt. I don't think anyone here would tell you going with that engine is a bad idea. In fact, I and many others would love to do something like that. I've tossed around the idea of a L28ET dune-buggy, too. There's no good reason to go with anything other than the Nissan transmission whether you go auto or 5spd. Get it going soon and take lots of pictures! Quote Link to comment Share on other sites More sharing options...
Madkatt44 Posted May 16, 2008 Author Share Posted May 16, 2008 Ya the whole setup only cost $1000 can, which in my opion isn't much at all. I've hada few ppl in the bast on this forum try to tell me not to bother and lol i don't like ppl telling me i can't or should not do things unless it for an actual valid reason , lol that would be a dam fast dunebuggy, I'm juts finishing up the body right now, but i will post the pics soon. Any ideas on how to mount the engine securely, I.e. no stress cracks later on and so forth? The real good thing about the motor is its a little bit shorter then the SBC thus give me more leg room in he cockpit. Plus i think a hot rod with an IC sitting out in front of a rad will look kick [@ZZ] p[lus the two turbos if i did my measurements right will stick out just past the hood and will draw fresh col air and it will look awesome with the filters sticking out of both sides of the engine bay. Quote Link to comment Share on other sites More sharing options...
Madkatt44 Posted May 17, 2008 Author Share Posted May 17, 2008 Does the 30DETT come stock with an IC?? Quote Link to comment Share on other sites More sharing options...
Madkatt44 Posted May 19, 2008 Author Share Posted May 19, 2008 Are the turbos on the DETT water cooled and is it feesable to run an IC with a 2 in and 1 out to TB? Quote Link to comment Share on other sites More sharing options...
RedEvilrps13 Posted May 20, 2008 Share Posted May 20, 2008 30dett's came with side mount intercoolers. Quote Link to comment Share on other sites More sharing options...
Madkatt44 Posted May 22, 2008 Author Share Posted May 22, 2008 What car do i ask for when i order the engine rubber mounts for the DETT or for the matter any other engine parts? I'm gonna kustom fab. the mounts and support brackets. Any suggestions??? If i 'm not running a hood and since its a hot rod would placing the ICs behind the rad. be ok? maybe with a slim fan. Quote Link to comment Share on other sites More sharing options...
evildky Posted May 29, 2008 Share Posted May 29, 2008 uh, just to clear a couple things up, I belieeve you are wanting the CG30DETT, as far as I know the VQ30 didn't come turbo'd, and if you're doign a custome setup on a rod why both er with stcok intercoolers? why not air to water coolers taht you can tuck behind froa rails, and if doing a custome setup why use stock mounts? fab some brackets and use the cheap GM urethane's for a fraction of the cost and yes you can do a 2 in one out intercooler but the VG30DETT uses twin inlets so you'd then need to split that outlet no offence but it sounds like this might be a bit much for your skill level based on the questions you are asking Quote Link to comment Share on other sites More sharing options...
