rustrocket Posted May 19, 2008 Share Posted May 19, 2008 I figured this belonged here more than the electrical section. To all those who have done the ls2 swap. Did you have somebody edit the PCM or did you do it yourself? I've been told i need to remove the vats, speed limiter, rear 02 sensors,various emissions, tank pressure sensors, engine torque mgmt, skip shift, etc. Whats the easiest and cheapest way to do this? Thanks! Quote Link to comment Share on other sites More sharing options...
ezzzzzzz Posted May 19, 2008 Share Posted May 19, 2008 You can find a lot of info on programming at LS1tech.com. It doesn't matter what car you're dropping the LSx engine in. Cheapest means is paying someone for a one-shot deal. If you're so inclined you can buy a single license/program to modify your PCM at will for a few more dollars. Quote Link to comment Share on other sites More sharing options...
mas28O Posted May 20, 2008 Share Posted May 20, 2008 Take you ecm to Newtech in Hayward or Synergy in Freemont to have the ecu flashed. Mike Quote Link to comment Share on other sites More sharing options...
