Buma Posted May 27, 2008 Share Posted May 27, 2008 I'd rather not have to buy a whole new Distributor because the VA doesn't work. Is there any place that I could get a new VA? Â Symptoms: When punching the gas it hesitates quite a bit, horrible mileage and some smoke. Â When hooking up the VA to the constant vacuum (it has 240z SU's) the engine revs up a little, but with the variable vacuum port on the carbs, there is no effect when reving the engine. Â So that's why we think the VA is failing. Â Also, does anyone know what the stock timing is for the L26? It doesn't run too well when it was where I got it. We manually advanced it a little w/o a timing gun and it does run a little smoother. Quote Link to comment Share on other sites More sharing options...
Zdigg Posted May 27, 2008 Share Posted May 27, 2008 Good luck with finding a V. Advance, I gave up and got a whole new distributer. Quote Link to comment Share on other sites More sharing options...
zcar74260 Posted February 15, 2009 Share Posted February 15, 2009 get a vacuum advance at schucks for 50 bucks Quote Link to comment Share on other sites More sharing options...
