how much vacuum at crank and idle?
SidWell
I am trying to figure out if I have a vacuum leak. While monitoring the Megatune 2.25 I am watching the vacuum reading. It is usually in the 90 KPA area. How much vacuum can I expect to see while the engine is cranking? How much is normal during idle?
30-40kpa at idle is a pretty normal number with a stock cam. With a bigger cam you may see 50-60kpa (based off numbers I've heard quoted in in. hg.). Depending on your altitude, 90kpa will be at ambient pressure or just a little lower. Definitely not a good idle vacuum reading.
