Directional failure
so since i have had my car the directionals have worked, no worked, worked.....and so on
so i am trying to figure out where the problem is. my buddy (a z maniac) tested a few things and everything is getting power, and the relay works for the hazards. you can hear it click but nothing lights up. the switch is also fine. basically i am getting no results from anything for the most part. anyone have a similar problem?
and when trying to tell me how to fix it, please speak to me like i am in 3rd grade. i know very little about what is called what, so try to be as simple as possible and describe what the part looks like please. thanks!
If everthing that you describe is functioning then the problem would be with the flasher-can, a connection in the lamp housings, or grounding issues in the tail clip.
I would take a good look at grounds in the tail clip... below the combo lights. You really must have a good ground there.
