tonycharger72 Posted June 6, 2008 Share Posted June 6, 2008 Was wondering if anyone can point me in the right direction, I have an RB30 powered Zed and am using a heavy duty clutch, but it is really heavy, I was wanting to change to a bigger master cylinder and appropriate slave cylinder, Initially when I did the conversion to the RB30 engine and 5spd (same as Turbo RB20 gearbox) the clutch wouldnt engage properly at all, so changed to a smaller (Think it was smaller) slave cylinder and adjusted the clutch to the limit of its throw, that was able to give me a clutch pedal!!! But its f#cking heavy, So my question is, What are my options for increasing the size of the stock 240/260z Clutch master cylinder? Anything that is bolt on? I can probably bore out my existing clutch MS, but was hoping that something from another Datsun/Car might serve the purpose??? Quote Link to comment Share on other sites More sharing options...
Clifton Posted June 6, 2008 Share Posted June 6, 2008 What PP are you running? I'm running a Supra ACT Xtreme PP with the stock master cylinder and have no problems other than a tired leg. Did you put a step on the flywheel wheel? Quote Link to comment Share on other sites More sharing options...
tonycharger72 Posted June 6, 2008 Author Share Posted June 6, 2008 I remember when I first did the conversion I was a bit strapped, so the new clutch I bought wasnt anything to fancy, just went down to a local parts store and bought a Heavy Duty clutch, which came with the PP - I had the option of a stock clutch and PP or the heavy duty one - thought the heavy duty was a better idea as its a bugger to change it when it burns out , My clutch works, but its just really heavy, so want to make it a bit easier on my left leg just because its my daily driver, Does Tilton make anything that will bolt into a Zed? Quote Link to comment Share on other sites More sharing options...
