Spicer chevy u-joint to datsun adapter!
Guest John Adkins
Guest John Adkins
I was checking into the chevy ujoint to datsun adapter to see if it was available from another supplier besides NEAPCO, and I
found that Spicer also makes a smiliar flange yoke with the same part# (2-2-899) specs on Dana-Spicer 2-2-899
From what I can tell from the spicer info, this part is a pretty common yoke for Nissan and Toyota pickup trucks... and John's Cars is charging $150.00 for it...
I was looking at Dana-Spicer's web pages, and it looks like that with a little research, you could build some heavy duty half-shafts from off the shelf spicer parts!
[ July 31, 2001: Message edited by: John Adkins ]
Thanks John,
BTW, any indication one with a 2.25" pilot is available? The R200 pinion flange I have is 2.25" instead of 2.00", and the NEAPCO part is for the 2.00" one. I have a custom made adapter, but the guy that built it made it with threaded holes for the 4 bolts, no room for a nut. I don't like drivetrain bolts in shear in the threaded region.
Guest John Adkins
Pete,
The Spicer flange yoke has a 2.25" pilot...
Just wondering,which is more common, the 2.00" or 2.25"?
quote:
Originally posted by pparaska:
Thanks John,
Guest John Adkins
Oops, I meant which is more common, R200s with the 2.25" pilot or the 2.00"... I didn't word my question in the above post clearly... I better get some sleep icon_redface.gif
[ August 01, 2001: Message edited by: John Adkins ]
  • 3 years later...
Thanks John' date='
BTW, any indication one with a 2.25" pilot is available? The R200 pinion flange I have is 2.25" instead of 2.00", and the NEAPCO part is for the 2.00" one. I have a custom made adapter, but the guy that built it made it with threaded holes for the 4 bolts, no room for a nut. I don't like drivetrain bolts in shear in the threaded region.[/quote']
Its been awhile, has any made an adapter for the 2.00" pinion flange? I have a 1975 with the 2.00" flange.
Thanks guys.
