rvandivort Posted July 8, 2008 Author Share Posted July 8, 2008 Actually,(for nc chris) had to order a rather large internal snap ring remover--15 1/2"--off of ebay. Cost Me about 67$ w/shipping. Worked in about 3 minutes with removal of the exhaust end and bumping out of the exhaust section. The pin was gone (thru corrosion ?), so no grinding was necessary. I`m wondering about the necessity to remove the wastegate actuater bracket now, as it looks like it it might have worked. But, a piece of aluminum strap will work with a half hours fabrication..or less. So.. Does anybody need a 15 1/2" internal snap ring tool good for 6"? Thanks, Roger Quote Link to comment Share on other sites More sharing options...
HoustonZ Posted July 8, 2008 Share Posted July 8, 2008 I do, I do!! I stupidly did not realize that mine actually needs to be rotated too. Is there any way I could borrow it asap? Quote Link to comment Share on other sites More sharing options...
rvandivort Posted July 8, 2008 Author Share Posted July 8, 2008 Cold Fusion, How `bout splitting the cost? I still have the shipping box. Quote Link to comment Share on other sites More sharing options...
rvandivort Posted July 8, 2008 Author Share Posted July 8, 2008 I`m going to Leavenworth tomorrow to get the wastegate lever welded. I could send it to You then. Quote Link to comment Share on other sites More sharing options...
rvandivort Posted July 12, 2008 Author Share Posted July 12, 2008 My reference to grinding the puck refers to grinding the edge..and not much.Furthermore,I had a heavy ruster, and all above refers to that situation. Thanks for all your help, Roger Quote Link to comment Share on other sites More sharing options...
rvandivort Posted July 18, 2008 Author Share Posted July 18, 2008 OOPS, The wastegate is STAINLESS STEEL!!! The brazing thing does not work. It grabbed into the lever, but not the pin. So, I am having friend Tig weld it (stainless steel job). I wonder about the different models of Holset. I have a 02 model. 2400 dodge. It has mystified Me ,seeing all the different ways of approaching the problem. I am assuming there was a big change the next year . Quote Link to comment Share on other sites More sharing options...
rvandivort Posted July 18, 2008 Author Share Posted July 18, 2008 I mean we have the Vband stuff on the exhaust--Don`t have that. I have a 5 bolt. Please explain this stuff. Quote Link to comment Share on other sites More sharing options...
rvandivort Posted July 27, 2008 Author Share Posted July 27, 2008 Had a buddy tig weld it. The play between the lever and the puck(causing interference --and thus total closing--was taken care of by center punching the waistgate puck and arm in several locations. Quote Link to comment Share on other sites More sharing options...
rvandivort Posted July 29, 2008 Author Share Posted July 29, 2008 And thus eliminating the play between puck and lever arm..mostly Quote Link to comment Share on other sites More sharing options...
rvandivort Posted July 29, 2008 Author Share Posted July 29, 2008 Well Enough anyway--it works perfectly!! Quote Link to comment Share on other sites More sharing options...
rvandivort Posted July 29, 2008 Author Share Posted July 29, 2008 Ran an air compressor check on it.....allright! Quote Link to comment Share on other sites More sharing options...
rvandivort Posted August 2, 2008 Author Share Posted August 2, 2008 Had another problem with assembly with the engine. The turbo would not mate. Had to grind 1/8"+ off the exhaust manifold and 1/8" off the turbo to make it fit. Also, when fitting the bolts the lower back nut did not fit.I tried (stupidly) to grind it down to 9/16 size. It did work...but, I decided to pull it off and grind the housing instead.....YESS. The nut clears.I used an aluminum H chanel to secure the T3 dual wastegate actuater to the turbo intake with screws on the flange and JB weld for security. Quote Link to comment Share on other sites More sharing options...
rvandivort Posted August 4, 2008 Author Share Posted August 4, 2008 Others have done a 1/2" spacer for this. But, this took care of the problem. Quote Link to comment Share on other sites More sharing options...
