Guest Will Posted August 3, 2001 Share Posted August 3, 2001 Subject says it all. Quote Link to comment Share on other sites More sharing options...
Guest scca Posted August 3, 2001 Share Posted August 3, 2001 quaiffe in calif has them and i believe Tom in NY has them as well, do a search for LSD . Tom arranged a group buy for them about 2 years ago and may still have a line on them.. on a Fiero note if your looking for a real GT rear spoiler i have one for sale .... [ August 03, 2001: Message edited by: scca ] Quote Link to comment Share on other sites More sharing options...
Mike C Posted August 3, 2001 Share Posted August 3, 2001 These guys have similar gear bias diffs. .Quaife America They have an application list with prices. The r200 is $1195 but is for 10 or 12 mm ring gear bolts. Reider racing has r200 clutch type limited slips for $550 but only for the 12mm ring gear bolts. They have r180's for $525 Quote Link to comment Share on other sites More sharing options...
Modern Motorsports Ltd Posted August 3, 2001 Share Posted August 3, 2001 On my 'to do' list is produce the 10mm->12mm bushings so the 10mm ring gear sets can be used easily with the 12mm units. The ring gear bolts do not seem to be a limiting factor (right Scottie , I know you're was welded and assume the bolts weren't welded as well ). If you're interested drop me a line, interest will bump it up my priority list. End result, you should be able to buy a new clutch setup for ~$500US and couple it with a used 10mm R200 and replace the bearings etc at your discretion/budget allowance. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted August 4, 2001 Share Posted August 4, 2001 Yeah, have some 2mm thick tube machined up and cut slices, pretty easy but super useful... Regards, Lone Quote Link to comment Share on other sites More sharing options...
