chb280z Posted June 16, 2008 Share Posted June 16, 2008 I was wondering if these are the same as the L28ET dished pistons? They are from my 77 L28E w/ the N42 head so early. And was going to turbo it and just trying to make sure that they would be ok? Thanks, Chris Quote Link to comment Share on other sites More sharing options...
m4xwellmurd3r Posted June 16, 2008 Share Posted June 16, 2008 the turbo and n/a dished pistons are the same, but i think the turbo's got forged pistons. I know the cast ones are ok to use on a turbo, but you'd want to use the P90 head (naturally, better flow, and a lower compression ratio to help you on boosting it) Quote Link to comment Share on other sites More sharing options...
1 fast z Posted June 16, 2008 Share Posted June 16, 2008 Ok, here is the REAL deal on the differences. NO Z car piston ever in the life of z cars has ever been forged from the factory. ALL Z car pistons 75-80 has a 10cc dish, with 2mm top comp ring, and 2mm second comp ring. ALL 81-83 Dished (turbo) pistons are exactly the same, EXCEPT they have a 1.5mm top compression ring. Quote Link to comment Share on other sites More sharing options...
chb280z Posted June 16, 2008 Author Share Posted June 16, 2008 so can i just get some turbo rings and be fine? And i have heard that the P79's flow the same as the P90 and would there be any really noticible power loss w/ the p79? Quote Link to comment Share on other sites More sharing options...
1 fast z Posted June 16, 2008 Share Posted June 16, 2008 P79, VS P90 stock, do flow the same, BUT you can work a P90 more extensivly, as the P79 ports are MUCH thinner, due to the semi vortex intake runner design. NO you cannot just throw Turbo rings on a Dished NA piston. Quote Link to comment Share on other sites More sharing options...
chb280z Posted June 16, 2008 Author Share Posted June 16, 2008 So should i try to find some turbo pistons or would i be better off just to spring for some forged pistons and what price range am i looking at for each? also 1 fast z since you are a head guy take a look at another thread i started and see if you can give some insight there. http://forums.hybridz.org/showthread.php?t=133489 Quote Link to comment Share on other sites More sharing options...
steveosupremeo Posted June 16, 2008 Share Posted June 16, 2008 why not just get some new rings for the pistons you have?? stock 75-80 piston rings. makes sense. Quote Link to comment Share on other sites More sharing options...
chb280z Posted June 17, 2008 Author Share Posted June 17, 2008 i guess that would make sense. and as for other parts when i am putting this thing back to gether shoulg anything alse be changed from OEM (ie. berings...) or will direct replacments from black dragon be ok? Quote Link to comment Share on other sites More sharing options...
