Armand Posted June 24, 2008 Share Posted June 24, 2008 Hello everyone, Has anyone tried the Greddy R200 finned diff cover and know if it clears everything on a 240z? Quote Link to comment Share on other sites More sharing options...
bjhines Posted June 24, 2008 Share Posted June 24, 2008 I am not even sure the bolt hole spacing is correct for the 280Z mustache bar. Not that you can't modify that for proper fitment. I looked into that piece and decided to stick with the stock cover. I decided to go with a Tilton fluid pump/cooler with a return port on the front channel of the diff case. I didn't want to reduce the stiffness of the rear control arm mounts with the bent-bar style lower cross-tie. I can add plenty of fluid capacity with a canister filter in the fluid-cooler system. Quote Link to comment Share on other sites More sharing options...
HarrisonTX Posted June 24, 2008 Share Posted June 24, 2008 nearly $400? wow thats a ton for a little extra oil. I would just drill and tap the stock cover, and run a cooler Quote Link to comment Share on other sites More sharing options...
Armand Posted June 24, 2008 Author Share Posted June 24, 2008 Ah totally forgot about the bolt spacing. Ok thanks guys. Quote Link to comment Share on other sites More sharing options...
