gwnwar Posted July 5, 2008 Share Posted July 5, 2008 Building 1978z w/350 chevy with carb. Can I use the stock 280 elec fuel pump with a Holley pressure regulator with bypass return and gage up front. Will the stock elec pump be ok and last or should I replace it with a different pump?? If so which one and what output. Last owner who started this swap cut the fuel pressure and return lines/tube and vent tube just behind the trans mount and just ran a rubber fuel injector hose up front.. Would you still run the rubber lines from cut off point or steel lines.. Will stock line size be ok or should I go large..this is a mild 350. Thanks.. Quote Link to comment Share on other sites More sharing options...
