Check out this Valve Tool...
That'd be a really tight fit with the cam in. Secondly - if the head is off the car (and you've ever tried to remove keepers from a valve train with any kind of significant mileage) you'll know that the valve will just push right down out of the head when you push on the spring and try to compress it to get the keepers out. Need some way to support the valve and keep it on the valve seat (I've used styrofoam before). Cool tool though. Someone needs to buy one and check it out!
If you noticed on the video, the guy laid down those orange half-balls . I think they are called valve stoppers and the sell them also for 3.50 in the purchase page. You're absolutely right about the valve going down to the cylinder when doing this in-car!!!
The shop I used to work at used a very similar tool on a 2JZ-GTTE engine. The shop owner got it from the local supra specialist.
We stuffed the cylinder with nylon rope to use as a valve stopper.
The technician said that it was one of the easiest valve stem seal replacement he had ever done.
Dunno if it will work on the Z though...
Mario
