83turbo280zx Posted August 2, 2008 Share Posted August 2, 2008 this is for my 83 zx turbo ok so i ditched my fan clutch and put on an electric fan w/ the same diameter as my fan clutch, i believe its 12". for the power source i used the boost sensor since all it does is provide a signal to the stock boost gauge (as far as i know) and i have a better analog gauge anyways. so im driving home and its getting as hot as it does during the day here in texas, and it never gets that hot at night, does it have anything to do with the fan shroud being off, i removed the shroud to get to the fan clutch and what not, but i never put it back on. could it be this alone? or do i need to get another fan to put next to it? i tried to do dual 12" fans but they wouldn't fit, so im either going to get a smaller 10" fan and put it next to it, or use my other 12" fan as a pusher fan on the other side of the a/c condensor. what gives? any help @ all would be greatly appreciated!! Quote Link to comment Share on other sites More sharing options...
Tony D Posted August 2, 2008 Share Posted August 2, 2008 Check your post at the other Z-Site, you got a detailed answer there... Not going to retype it here. If you want to cut and paste the answer.... Quote Link to comment Share on other sites More sharing options...
