Tim240z Posted November 5, 2001 Share Posted November 5, 2001 Just did the monthly 'wrench check' on my 240 daily driver and found all of the bolts on the driveshaft loose . I hadn't noticed the increasing vibration until I tightened them an felt how smooth the car drives now . It's like a new car!! Boy, I'm glad I checked, what a drag it would've been if the dang thing had dropped out at 75MPH on the I-405 Looks like the diff mount is getting tired too......I also put the 160 deg thermostat in since the old one was letting the gauge get to over 3/4 before letting in the cool H2O. Now it runs at just over 1/3 on the gauge all the time Tim Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 5, 2001 Share Posted November 5, 2001 I check those as well, every trip under the car. Since the JTR conversion, I havn't had them loose, but the stocker u-joint bolts had loosened to finger tight when I pulled the driveline out, lucky I didn't through the shaft considering how loose they were. Good point checking them. Regards, Lone Quote Link to comment Share on other sites More sharing options...
BLKMGK Posted November 5, 2001 Share Posted November 5, 2001 I used Loctite on mine after having the rear of the shaft drop out and leave me stranded. If I weren't about to goto CVs in the next couple of months I'd have done the same to the halfshaft bolts. I use the red which requires heating to soften but I think blue doesn't require this? I don't mind needing to heat them Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 6, 2001 Share Posted November 6, 2001 Yep, blue doesn't need heating. I used blue on mine along with nylock nuts, seems to stay tight. *shrug* Regards, Lone Ps: Need some locktite for something and don't have any? Heh, I've used the wifes fingernail polish on the bikes bolt threads before and if a Harley ain't gonna shake a bolt loose, it must work pretty good.. Just return it though, they get pissy otherwise... [ November 05, 2001: Message edited by: lonehdrider ] Quote Link to comment Share on other sites More sharing options...
fl327 Posted November 6, 2001 Share Posted November 6, 2001 my favorite was when i discovered that the previous owner mixed up the driveshft bolts with two of the steering coupler bolts, sheared two of them clean in half. pretty cool huh Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 6, 2001 Share Posted November 6, 2001 I used ARP bolts and locking nuts .THEY HAVE NEVER MOVED !! Quote Link to comment Share on other sites More sharing options...
