Rear Widow Louvers and Spoiler
nick77
I have rear window louvers and spoiler the problem i have is i have no mounting hardware i dont even know if they are rivieted on or bolted on, i have searched the internet and the forum and came up dry, if someone could post pictures of how they mount or explain a way i could mount them, i also have the original holes there too.
Thanks in advance
Nick
Thanks in advance
Nick
Could you re-state your question or request with appropriate punctuation, please?
are you trying to mount the spoiler, the louvres, or both?
In have the stock slats/louvres and there are factory holes drilled (4) at the base of the window - there are 4 hand-tight screws that mount the slat assembly at the bottom; the top is secured with a set of hinges. but if yours is aftermarket, it may be a totallly different application.
Pics would help us help you more :)
yes i want to mount both its an original (as they get) aluminum louvers that fit out side the window and the spoiler is the 1 piece fiberglass that is the most common one.
I have no hinges or hardware so if i see a close up picture of how they mount i can make something up or get hinges from the hardware store.
Thanks
Nick
Thanks
Nick
First of all, Is this on an S30, S130, or Z31? I'll assume S30.
Philbert, I do not believe that any Z car came from the factory with louvers. I suppose it may have been a dealer option somewhere, but not factory.
I'll try to find a pic of how the louvers were setup on my Z. I still have the hatch so I can get pics of the 8 hole locations.
interesting! I had no idea. I just pulled out the records from the original owner (including the sticker from the sale), and cannot find it as an option.
