Guest znow white Posted August 6, 2008 Share Posted August 6, 2008 I have this relay from a 300zx its got pins 3 5 1 2 1. would those numbers be the wires directly across the relay 2. what are these in retrospect to the megasquirt schematic ? 85 86 87 30 im thinking 3=30 5=87 1=86 2=85 (just by matching the picture by im not sure again) so if i know the answer to the above questions i wire the relays on schematic 30= +12v all the time 87= power up MS2 85= GROUND 86= +12 v switched power? does my source have to have +12v when cranking as well? do i have to run 2 relays? i only got this one for now...cause the fuel pump relay is different pin 37 of db is going into 85 erh is it me or relays are damn confusing someone please let me know if im doing this right cause i dont want to fry anything Quote Link to comment Share on other sites More sharing options...
SidWell Posted August 6, 2008 Share Posted August 6, 2008 It looks right. Before you apply the power to the MS take a few minutes and power up the relay, take a multimeter to pins 3 & 5 and make sure it is closed. I would suggest that you learn a bit more about the relay you have. Specifically find out how much current it is rated for and where you can find a replacement. Quote Link to comment Share on other sites More sharing options...
evildky Posted August 7, 2008 Share Posted August 7, 2008 yes thts correct but if it confuses you just go to your local autoparts store and buy a standard automotive 5 pin relay, they contacts are labled with the same numbers shown on the schematic Quote Link to comment Share on other sites More sharing options...
Guest znow white Posted August 7, 2008 Share Posted August 7, 2008 i think im just going to go get 2 new standard bosche type relays so everything was right? 30= +12v all the time (should i get from batterey or alternator?) 87= power up MS2 85= GROUND 86= +12 v switched power? does my source have to have +12v when cranking as well? Quote Link to comment Share on other sites More sharing options...
dts300z Posted August 7, 2008 Share Posted August 7, 2008 If you disconnect the plug from the relay and get a light and look inside of the relay where the connector would plug in the numbers from the reverse side (or the top) will be next to the corrisponding terminals. Edit: and yes you are correct on your asumption! I use those relays all the time Quote Link to comment Share on other sites More sharing options...
evildky Posted August 7, 2008 Share Posted August 7, 2008 yes you need hot when cranking as well otherwise the MS unit will nto ahve power and your engine will crank with no fuel or spark Quote Link to comment Share on other sites More sharing options...
