R-200 swap , again
Having asked around and got different answers, I realized I should have gone her first bonk.gif I am changing the 180 for a 200 rearend. Do I need the moustache bar, front diff mount and 1/2 shafts from the R-200 donor car?? icon_biggrin.gif Thanks
What year is your car? Mine is a '72 and the donor rear was from a '78. All I needed was the mustache bar, everything else is same. If you have a 70 or 71, you also need the diff crossmembers and a driveshaft. Either way half shafts should be fine. This post probably should be in driveline section though...
