dtaylor Posted August 17, 2008 Share Posted August 17, 2008 I am starting to work on my axle assemblys. I ordered my axles for MM. Are they suposed to be able to ride back and forth on the shaft? I would not think they should. Did I get a set of axles that were machined wrong? If you have done this swap to your car please tell me this is normal. Picture of what I see below.. Quote Link to comment Share on other sites More sharing options...
WizardBlack Posted August 21, 2008 Share Posted August 21, 2008 I am starting to work on my axle assemblys. I ordered my axles for MM. Are they suposed to be able to ride back and forth on the shaft? I would not think they should. Did I get a set of axles that were machined wrong? If you have done this swap to your car please tell me this is normal. Picture of what I see below.. Just a guess, but... The included c-clips stop it from sliding off the end and when they are assembled they can't slide "in". I have four CV shafts and Ross's entire kit sitting in my shop waiting to be installed, too. Quote Link to comment Share on other sites More sharing options...
Nigel Posted August 21, 2008 Share Posted August 21, 2008 There should be snap rings on both ends of that bearing race to locate it on the shaft. It's not meant to slide on the shaft in either direction. NOTE: I just noticed that this is for a Q45. I don't know if that makes a difference... Nigel '73 240ZT Quote Link to comment Share on other sites More sharing options...
WizardBlack Posted August 26, 2008 Share Posted August 26, 2008 There should be snap rings on both ends of that bearing race to locate it on the shaft. It's not meant to slide on the shaft in either direction. NOTE: I just noticed that this is for a Q45. I don't know if that makes a difference... Nigel '73 240ZT IIRC I have four c-clips in the MM kit. Quote Link to comment Share on other sites More sharing options...
dtaylor Posted August 26, 2008 Author Share Posted August 26, 2008 Got a response from Ross about it. He told me it was okay and nothing was wrong. It would not hurt anything to have that gap then there. So I have installed them and moved the car in and out of the garage a couple of times with no problems.. Quote Link to comment Share on other sites More sharing options...
